like these
Airfoil lofts are possible with Inventor, but they could behave better. See 2016 file.
Airfoil points are imported from an Excel file. Three import options are available:
- Only points import
- Import of points, connected with straight lines
- Import of points, with spline connection
Now look at the results:
Wing root section has 100% depth, wing tip section has 60%.
The red wing used points with straight lines import. Automatic transition points were set for the loft. When looking along the trailing edge, line shifting can be seen. This result is bad, and can only be accepted for far-away looks. Disturbing are many tesselation lines, too.
The yellow wing used points with straight lines, too. But in this case, the sections were split up in upper and lower sections, together with 3DLines for leading and trailing edge. Nose portion is better now, but there are still misalignment between transition points at the lower section. That could be better,too.
The blue wing is made from points with spline import. No more tesselation lines are visible, but scaling down the tip to 60% fails. I didn't find a solution for that unsatisfying result.
What do we need?
- Better scaling for spline sections
- Point-to-point transitions between loft sections with only scaled or similar geometry
Let's hope for early improvements
Walter
Walter Holzwarth
