Inventor Forum
Can you embed excel after linked
7 REPLIES 7
Message 1 of 8
361 Views, 7 Replies
I have a part which is linked to an excel spread sheet. Now I would like
that spread sheet embedded. Is that possible?
Lester Martin
7 REPLIES 7
Message 2 of 8
Embedded in the IDW or the IPT parameter list?
K
"Lester Martin" wrote in message
news:02FC90FC9C0B200616F8ABE85D62F93D@in.WebX.maYIadrTaRb...
> Lester Martin
Message 3 of 8
IPT parameter list
"Karl Maas" wrote in message
news:F44E8F1F699A6286E72CAA565992263D@in.WebX.maYIadrTaRb...
> K
> > Lester Martin
Message 4 of 8
The only way I know to do this is long and nasty:
1. RMB on each param in the params menu and choose Add to user params.
They will be moved to user params
2. After each one has been added then RMB on the excel sheet in the browser
and delete
3. Change each of the user param names to something else (e.g. length to
length2)
4. Reinsert the Excel sheet and embed
5. In the params menu make the value of the user params length2 for example
= to the name of the embedded param (e.g. length2=length)
I told you it was nasty. If anyone has a better suggestion I'm all ears...
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
> Lester Martin
Message 5 of 8
Boy when you say long and nasty you mean long and nasty.
I don't want to do this too often.
Thanks anyway.
"Sean Dotson" wrote in message
news:15D54F6216F6FB8E352D100FE8FBD4FF@in.WebX.maYIadrTaRb...
browser
> and delete
> length2)
example
ears...
> Sean Dotson, PE
> > Lester Martin
Message 6 of 8
for starters, instead of your step #1 you can RMB on the folder heading and
select delete folder which will take all the params and make them User
params in one shot.
Secondly, I managed to accomplish what we're after, but alas, I can't
reproduce it. It had something to do with using the inserting an object from
the Insert pulldown before removing the link to the spreadsheet. The params
somehow magically jumped from the referencing the link to referencing the
embed. I'll see if I can figure it out.
K
browser
> and delete
> length2)
example
ears...
> Sean Dotson, PE
> > Lester Martin
Message 7 of 8
Thanks for the tip on #1. I'll file that one away.
If you figure out how to get the second part to work be sure to let me know.
I've tried many ways before but could never get it to work...
Sean Dotson, PE
news:09212D3FC152B4571B48E12D3973C5CD@in.WebX.maYIadrTaRb...
and
> params in one shot.
from
params
> K
> browser
> > and delete
to
> > length2)
> example
> ears...
> > Sean Dotson, PE
like
> > > Lester Martin
Message 8 of 8
I tried and tried then went back to the example that worked and realized
that it hadn't worked, sorry for the false hopes. I'll go clean the egg off
my face now.
K
news:1D9C376ED408215F8534742E437084DC@in.WebX.maYIadrTaRb...
know.
> Sean Dotson, PE
> and
> > params in one shot.
> from
> params
the
> > K
params.
> > browser
> > > and delete
> to
> > > length2)
> > example
> > ears...
> > > Sean Dotson, PE
> like
> > > > Lester Martin
