Steve Walton
Steve Walton
I realize that this is 9 years later but I have the same problem now as gcross. I believe you missed that he said the delete row button is greyed out.
OK, so, what you do, is copy-paste the line above the one you want to delete into the last row, and then delete the rev line above the last one (that you just copied from)... because that makes sense.
Hi! The behavior does not sound right to me. Could you share an example? Please send it directly to me (johnson.shiue@autodesk.com).
Many thanks!
I believe it was originally intended to tie in with some sort of document management system and we were probably not even supposed to be able to access it from within Inventor.
Notice how the text you type in in the Revision Table dialog is blue, like overridden text in a Parts List - as if you are overriding the text that the document management is supposed to provide, and the "paperwork" for the change is already on its way through that system. Now you can't stop it, so you have to do a revision to undo the revision when a rational person would ask, "Why can't I just delete it?"
But you and I should be able to just delete it because we are not using the other system - for all I know that other system was never even implemented.
Can you "leave" a General Table in a template? Remember drawings that looked like this:The rev table was always there with empty lines.
We could make our own - do you use the Revision Tags? (You could make your own with Sketched Symbols - And that will help out when you discover that two or three revisions ago somebody missed a revision tag - - just try and place an old tag, I was once trying to redraw a pencil drawing and thought I could place all the tags for 20+ years of revisions at once, ha ha. So there's a drawback to the convenience of the auto indexing of the tags.)
The only thing their revision system really has going for it is that we can't save a format for a general table.
(You could put that in the Ideas forum "Styles for General Tables" or something like that.)
The revision row non-removable behavior happens with every line drawing. When you create one, make the mistake that you add a row then change your mind and want to just delete it. From what I am hearing/reading, deleting the row is not possible.
Still an issue in 2022.
Situation. Copying an existing drawing that is very similar to the drawing that is needed, swapping out the model reference and updating title block information in an attempt to create a NEW drawing with minimal work.
If a revision exists in the drawing, then you can't remove those revisions to start over and you "must" start fresh and anew to clear the revision history.
llorden4, I do the exact procedure you describe often. I delete the old Revision Block all together then drop a new Revision Block in. It works for me every time.
