Inventor Forum
Can not open a new file in Inventor 2014 (new istallation?)
3 REPLIES 3
maximiliandahlenburg
273 Views, 3 Replies
In the right upper corner of autosek Invetor 2014 is a button wich says New (NEU = German) if i click there the window gets bright gray and says no response (keine Rückmeldung) ... i started the Laptop several times but it never Works.
technical support is not available so what shall i do ?
Reinstall?
Greets Maximilian Dahlenburg
3 REPLIES 3
Can you also post a screen shot showing what you are describing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Yes i have tried both reinstall and repair...
should i redownload and before that delete everything ?
