So based on this posting https://forums.autodesk.com/t5/inventor-forum/inventor-studio/td-p/7850165 I created a positional rep of the human hands based on constraints. In one studio (pos rep) animation I got the left hand to move in the positional rep animation. Good so far... Well that's what I thought.
Now I created another positional rep animation in studio to move both the left and right hand at the same time. I can change the positional rep in the model with no problem However when I go to animate that positional rep in studio it tells me it can't use that positional rep and to select another one. So I went back to my model to see if I made a mistake and the positional rep I was using is no longer in my model. I went to add it again and it tells me the name already exist. I created a new one thinking I made a mistake. Repeat the process in Inventor studio and get the same message. Then I thought perhaps I'm unable to animate two sub-assembly positional reps at the same time. Decided to go back to the model and make them separate. But guess what, the new positional rep I just created in the model is also not listed in the model by you can't use the name again because it thinks its still there.
@johnsonshiue and @Xun.Zhang what's going on?
Forgot my screen shots
Here's the assembly with the positional reps
Here's the message:
Here's the browser after I get back out of studio.. You can now see the positional reps of HOLDMATL is missing.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Solved by Xun.Zhang. Go to Solution.
Hi Mark,
From your description, it is a critical pos rep data loss defect since it was invisible in browser tree but it was "there".
Would you mind share me your simplified dataset (xun.zhang@autodesk.com) to me to check what's wrong in it.
Or would you mind follow below VBA to delete the exited "HOLDMATL" and recreate it again?
'This assumes an assembly document is open.
Sub Deletespecifyrepresentation()
Dim oDoc As Inventor.Document
Set oDoc = ThisApplication.ActiveDocument
Dim oCD As ComponentDefinition
Set oCD = oDoc.ComponentDefinition
Dim oPR As PositionalRepresentation
Set oPR = oCD.RepresentationsManager.PositionalRepresentations("HOLDMATL")
oPR.Delete
End Sub
Hi Mark,
The problem was identified finally and tracked by ticket INVGEN-14041.
Thanks!
Hi Mark,
As a workaround, you can first activate the Pos Rep in the top assembly, then switch to Studio and create the animation from Master to MATL_HOLD.
I tried in my side, it works with this activated Pos Rep in advance. Let me know whether it works for you.
-Lisa
