Inventor Forum
BOM Settings for Drawings
4 REPLIES 4
BDUB2012
1074 Views, 4 Replies
Correct me if I am wrong and please let me know what I am doing wrong and how to do it.
I thought when you created a part and filled out the iproperties description field and created a drawing of that part that the parts list would read the iproperties description field and put that in the parts list description field.
Then when you create an assembly that included that part and filled out the iproperties description field in the assembly and created a drawing of that assembly that the parts list description field would be filled out be the assembly iproperties description field.
Instead the description field of the parts list in the assembly drawing is filled out using the iproperties description field of the part not the assembly.
Please let me know where my thinking is wrong and how to correct it.
Thanks.
4 REPLIES 4
in reply to: BDUB2012
BDUB2012, I believe that the BOM should extract the iProperties from the part file by default. However, I do think it is possible to use the assembly BOM as well, but I have forgotten how to do that as it is something I rarely use.
Search the following address for more information regarding the BOM and it's operation.
http://wikihelp.autodesk.com/search?source=help&product=Inventor&q=BOM&language=ENU&version=2013
The parts list description pulls the description from the iproperties of the part.
The only way you would get the description from the assembly iproperties, is if you use the assembly in another assembly (as a subassembly).
What are you trying to accomplish?
jletcher
If you really want the assembly to show up in the BOM as you request you could make a Virtual Component with the Assembly information this will act as the assembly.
 This is not the norm but this is how you can get what you want.
And please post the version of Inventor you are on on next post this helps us.
BDUB2012
in reply to: jletcher
I aplogize, the version is 2012.
The solutions that I have found to get an assembly bom on an assembly drawing are:
1. insert an assembly into an assembly.
2. make a virtual part or derived part.
3. make extra fields in the part and have the BOM column look at alternative iproperty fields.
In a part file that has a family table I want the configurations of some casted parts and some machined parts. the casted parts will have a drawing but no BOM, the machined parts will have a drawing and a BOM.
Then in an assembly file that has a family table I want configurations that use the configurations of the part file. Each of these assemblies will have a drawing that has a BOM that will call out the part that is is made from.
In other words I will have a casting that will be machined so I will need a casting drawing and a machine drawing that has a BOM telling what casting to use.
Is there any easy way to do this.
On top of that when I try to make a family table in an assembly I get a message "THE BILL OF MATERIALS CONTAINS VIEWS OR PROPERTIES NOT SUPPORTED BE CONFIGURATIONS. OONLY STRUCTURED FIRST LEVEL BOM VIEWS ARE SUPPORTED. THE BOM WILL BE CHANGED DURING CONVERSION".
I do not know what i changed so I do not know how to correct it.
Please help with any solutions.
THANKS!
