when i generate a parts list and auto balloon, both are skipping a number. The list and balloons jump from item number 13 to 15 and there are no item 14.
using Inventor 2015
Thanks.
Hi gtoutounji,
Can you post the files that exhibit this behavior?
I hope this helps.
Curtis
im not sure why its doing that but if you hit the renumber items button, then the save items overrides to BOM button, that should work. (when you double click your BOM)
Thank you both for the help. I am new to Inventor. How can I send the drawing file with all its references? I tried Pack and Go but the button is greyed.
Thanks.
Thanks.
Pack and go should work..
Its as simple as gathering up the idw, the iam and any associated ipt files and zipping them up..
But with a large assembly that can be quite a bit..
Are you using pack and go through windows explorer? or through save as?
I am using Pack and Go through Save as. it does not work and i don't know why.
