How to stop Bolted Connection Component Generator to reset all my previous modification when I open the dialog again? It's extremely disturbing.
Symptomes:
Here is GIF - I had modified hole under screw head - it's fully sunk. Then I only open the dialog and press OK - Bolt head is above the surface.
Thanks for help.
Hi @j.pavlicek,
I made a some tests but I could not find any general issue with the workflow you described. But from the GIF I was not able to clearly see all the settings that you used. Could you provide the following information so that I can try to reproduce the issue on my system?
Kind regards,
Jens Krause
Autodesk Support
Hello @j.pavlicek,
finally I am able to reproduce your issue. Unfortunately I do not have any workaround for now.
Ticket INVGEN-13208 was open to track it down.
Regards
Dear @j.pavlicek
you can use the following public link to track the state of the ticket:
Inventor: Editing a Bolted Connection resets modified parameters
(Please regard that it may take up to 24h until the article is available online)
You will be informed automatically by e-mail when the state of ticket changes.
Kind regards,
Jens Krause
Autodesk Support
Hi @j.pavlicek,
as a workaround you can set the hole diameter to 'Custom' type. Then all customization would persist.
Mirek Groh
Inventor Development
