Hi all,
I have updated autodesk inventor professional to 2017 version, and (I don't know if it's from the update or if i had disabled something) I can't see the 3 axis on the left bottom corner of the open file... Until now (2016 version) i saw 3 arrows, red,green and blue) and now I can't find any option to add again...
Best regards
Herculano
Solved by mdavis22569. Go to Solution.
Solved by JDMather. Go to Solution.
Tools>Application Options>Display tab and checkmark Show Origin 3D Indicator.
make sure it's turned on in the application options
It "may" be a graphics driver issue if the above setting doesn't bring it back...
And of course you do have a file open right? Without any files open you will just see a background with no origin indicator..
Tkank's to you all!
It was so easilly that I can't see with my eyes 😉
I had cheking all options on "application Options" and I don't see the options you gave me 😉
Tkank you all again.
Best Regards
(problem finally solved)
