Inventor Forum
About the HRESULT:0x80020003 (DISP_E_MEMBERNOTFOUND))??
1 REPLY 1
Stakin
3054 Views, 1 Reply
this is my code to count all the Parts of an assembly,and sort out all the normal Parts from it (store in an arraylist)?
but some times it can work perfectly,sometimes it lead to an error of HRESULT:0x80020003.
System.Runtime.InteropServices.COMException (0x80020003): Can not find Member。 (Error From HRESULT:0x80020003 (DISP_E_MEMBERNOTFOUND))
   In Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
   In LmiRuleScript.SaveToCSVFile(Document asmDoc, String FileDir, ArrayList oFNL, ArrayList oFNLL)
   In LmiRuleScript.Main()
   In Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   In iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
 By repeatedly running the code,I found:
If I manually open the component files and parts, and then run the code, are generally not wrong, otherwise, an error will occur HRESULT:0x80020003.
how to solve this problem?
Imports System.IO
Public Sub Main()
	Dim SelectFile_DlgName	As String	=	"Please Select File"
	Dim my_File 			As String 	= GetDataFileName( SelectFile_DlgName)
	If my_File="Cancel"	 Then
		Exit Sub
	Dim oTDoc As Inventor.Document
    Dim oDoc As Inventor.AssemblyDocument
	oTDoc=ThisApplication.Documents.Open(my_File,False)
	If oTDoc.DocumentType<>Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("Not Assembly(*.iam)!",16,"FileSelect Error")
		oTDoc.Close
		Exit Sub
	Else
		oTDoc.Close
		oDoc=ThisApplication.Documents.Open(my_File,False)
	Call ChangePhMain(oDoc)
'	oCompDef = oDoc.ComponentDefinition
	Dim oFNL As ArrayList =New ArrayList()
	Dim oFNLL As ArrayList =New ArrayList()
	Call SaveToCSVFile(oDoc,IPJ_Folder_Location,oFNL,oFNLL)
	Call CreateIDW(oFNLL,oDoc)
	oDoc.Close
End Sub
Private Sub ChangePhMain(ByVal oDoc As Inventor.Document)
    Dim sMsg As String
	Dim oCompDef As Inventor.ComponentDefinition
    Dim iLeafNodes As Long
    Dim iSubAssemblies As Long
    Dim oCompOcc As ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        If oCompOcc.SubOccurrences.Count = 0 Then
			Call ChangeBOMStructureToPhan(oCompOcc)
            iLeafNodes = iLeafNodes + 1
        Else
            iSubAssemblies = iSubAssemblies + 1
            Call processAllSubOcc(oCompOcc,iLeafNodes,iSubAssemblies)
    Next
End Sub
Private Sub WriteStructure(ByVal oFNL As ArrayList,ByVal Occurrences As ComponentOccurrences, ByVal Level As Integer, ByVal SWT0 As System.IO.StreamWriter)
	Dim occ As ComponentOccurrence
	Dim Output_count As Double
	For Each occ In Occurrences
			oFNL.Add(occ.Definition.Document.FullFileName)
			SWT0.WriteLine(occ.Definition.Document.FullFileName )
		If occ.DefinitionDocumentType = kAssemblyDocumentObject Then
			Call WriteStructure(oFNL,occ.SubOccurrences, Level + 1, SWT0)
	Next
End Sub
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, ByRef iLeafNodes As Long, ByRef iSubAssemblies As Long)
    Dim oSubCompOcc As ComponentOccurrence
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If oSubCompOcc.SubOccurrences.Count = 0 Then
 			Call ChangeBOMStructureToPhan(oSubCompOcc)
        Else
            Call processAllSubOcc(oSubCompOcc, iLeafNodes, iSubAssemblies)
    Next
End Sub
Private Sub ChangeBOMStructureToPhan(ByVal oCompOcc As ComponentOccurrence)
'Inventor.BOMStructureEnum.kPhantomBOMStructure=51971
	If Left(oCompOcc.Name,8)="ISO 33.7" Then
		oCompOcc.Definition.BOMStructure=Inventor.BOMStructureEnum.kPhantomBOMStructure
	ElseIf oCompOcc.DefinitionDocumentType()=Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
		If oCompOcc.SubOccurrences.Count=0 Then
			oCompOcc.Definition.BOMStructure()=Inventor.BOMStructureEnum.kPhantomBOMStructure
	ElseIf oCompOcc.DefinitionDocumentType()=Inventor.DocumentTypeEnum.kPartDocumentObject Then
		If oCompOcc.Definition.SurfaceBodies.Count=0 Then
End Sub
Private Sub SaveToCSVFile(ByVal asmDoc As Inventor.Document,ByVal FileDir As String,ByVal oFNL As ArrayList,ByVal oFNLL As ArrayList)
	Dim csvFilename As String=Left(asmDoc.FullDocumentName(),Len(asmDoc.FullDocumentName())-3)&"txt"
	Dim saveDialog As Inventor.FileDialog
	Dim oProperty As Inventor.Property
	Dim j As Integer
	Dim i As Integer =0
	Dim SWT0 As System.IO.StreamWriter = New StreamWriter(csvFilename)
	Using(SWT0)
		Call WriteStructure( oFNL, asmDoc.ComponentDefinition.Occurrences, 1, SWT0)
	End Using
	Dim SWT1 As System.IO.StreamWriter = New StreamWriter(csvFilename & "-Count.Txt")
	Using(SWT1)
	oFNLL.Add(asmDoc.FullFileName() )
	i=0
	While(i<>oFNL.Count())
		Dim FNN As Integer=0
		Dim oFNNL As ArrayList =New ArrayList()
		For j= 0 To oFNL.Count()-1
			If oFNL(i)=oFNL(j) Then
				FNN=FNN+1
				oFNNL.Add(j)
		Next
		For Each oTTDOC In  asmDoc.AllReferencedDocuments
			If oTTDOC.FullDocumentName=oFNL(i) Then
				SWT1.WriteLine("{0}:{1}:{2}",oFNL(i),FNN,CStr(oTTDOC.ComponentDefinition.BOMStructure))
				If oTTDOC.ComponentDefinition.BOMStructure=Inventor.BOMStructureEnum.kNormalBOMStructure Then
					Try
						oProperty=oTTDOC.PropertySets.Item("D5CDD505-2E9C-101B-9397-08002B2CF9AE").Item("User-Count")
						oProperty.Value=Str(FNN)
					Catch
						oProperty=oTTDOC.PropertySets.Item("D5CDD505-2E9C-101B-9397-08002B2CF9AE").Add(Str(FNN),"User-Count")
					End Try
					oFNLL.Add(oFNL(i))
		Next
		If oFNNL.Count()>1 Then
			For j=1 To oFNNL.Count()-1
				oFNL.RemoveAt(oFNNL(j)-j+1)
			Next
		i=i+1
	End While
	End Using
End Sub
Private Function GetDataFileName(oDialgTitle As String	)    As String
	Dim oFileDlg As Inventor.FileDialog
	Call ThisApplication.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "AutoDesk Inventor File (*.ipt;*.iam;*.ipn)|*.ipt;*.iam;*.ipn|All Files (*.*)|*.*"
	oFileDlg.FilterIndex = 1
	oFileDlg.DialogTitle = oDialgTitle
	oFileDlg.CancelError = True
	Try
		oFileDlg.ShowOpen
		GetDataFileName = oFileDlg.FileName
	Catch
		GetDataFileName = "Cancel"
	End Try
End Function
1 REPLY 1
Stakin
in reply to: Stakin
The same code, but also led to another mistake  HRESULT:0x80004001
System.NotImplementedException: 尚未实现 (异常来自 HRESULT:0x80004001 (E_NOTIMPL))
   在 System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   在 Inventor.ComponentDefinition.set_BOMStructure(BOMStructureEnum )
   在 LmiRuleScript.ChangeBOMStructureToPhan(ComponentOccurrence oCompOcc)
   在 LmiRuleScript.ChangePhMain(Document oDoc)
   在 LmiRuleScript.Main()
   在 Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   在 iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
