Inventor Forum
a area, length and width of a flat pattern
3 REPLIES 3
611 Views, 3 Replies
I would like to add a area, a length and a width of a flat pattern to other Excel sheet. Now I see these dimensions from the drawing and I'm calculating a area of a flatpattern...
Could I be getting these values from Inventor easier way? I'm using iPart also. I think it help me if I would get values to Excel sheet for example.
3 REPLIES 3
jletcher
Look into ilogic. Getting this information is really easy in Inventor and exporting it is just as easy. Look into it and if you have problem come back and I and others can give you some pointers.
There are also post on this subject do a search and you will find at least 20 post on it.
here is code to create properties for flat pattern length and width.
export them to excel...
partDoc=ThisDoc.Document
Try
DimsheetMetalDefAsSheetMetalComponentDefinition=partDoc.ComponentDefinitionIf(sheetMetalDef.HasFlatPattern())ThenDimpropertySetAsPropertySetpropertySet=partDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")DimlengthPropertyAs [Property] DimwidthPropertyAs [Property] ForEachcustomPropertyAs [Property] InpropertySetIfcustomProperty.Name.Equals("FlatExtendsLength")lengthProperty=customPropertyElseIfcustomProperty.Name.Equals("FlatExtendsWidth")widthProperty=customPropertyEndIfNextIflengthPropertyIsNothingThenpropertySet.Add("empty", "FlatExtendsLength")EndIfIfwidthPropertyIsNothingThenpropertySet.Add("empty", "FlatExtendsWidth")EndIfiProperties.Value("Custom", "FlatExtendsLength")=Round(SheetMetal.FlatExtentsLength,2)iProperties.Value("Custom", "FlatExtendsWidth")=Round(SheetMetal.FlatExtentsWidth,2)
EndIfCatch
EndTry
I hope it helps
Curtis_Waguespack
Hi juha.lievonen,
Assuming you're not using an old version of Inventor you should be able to do this with a text note or sketched symbol, by accessing the Sheet Metal Properties as shown here. I think this functionality was added in Inventor 2009 or 2010. Getting the information to Excel will require the use of a custom iProperty as mentioned earlier.
I hope this helps.
Curtis
