Inventor Engineer-to-Order
omarutov
Message 1 of 21 (395 Views)
Accepted Solution
Work with Intent Design Editor
395 Views, 20 Replies
01-28-2013 10:56 AM
Couple days ago I have installed ETO R2 2013. When I work with Intent Design Editor I have some issue. When I try to input double number (as 2.25) I have some error message (see attached picture). What is it? How can I fix it?
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
After many trials and guesses, we have replicated this problem.  It occurs when there is a conditional child rule (the Design is conditional).  It is also a separate defect that turning Intellisense off does not stop the problem from happening.  The problem has nothing to do with drawings.  It is replicable with a trivial Design.
This problem is not present in ETO Studio.  That is the recommended workaround until a fix can be released.
--Jack Gregory
omarutov
Message 2 of 21 (394 Views)
Re: Work with Intent Design Editor
01-28-2013 10:59 AM in reply to: omarutov
In addition, the error message shown after input "."
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Employee
JackGregory
Message 3 of 21 (388 Views)
01-28-2013 11:30 AM in reply to: omarutov
Can you send or post the file that gets the error?
Hard to give much advice without seeing it.
--Jack Gregory
omarutov
Message 4 of 21 (364 Views)
01-29-2013 11:34 AM in reply to: JackGregory
Too hard to say what file gets this error. I have this issue when I work with sheet in Intent through Design Editor.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Employee
JackGregory
Message 5 of 21 (357 Views)
01-29-2013 12:11 PM in reply to: omarutov
OK.  The next time you see this problem, please send (or post here) the full backtrace as shown in that error dialog, and the file you are editing at the time.  It looks like an intellisense error, which should be something we can track down.
--Jack Gregory
omarutov
Message 6 of 21 (345 Views)
01-30-2013 11:37 AM in reply to: JackGregory
This is exception text.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
at Autodesk.Intent.Utilities.EqualsName(String name1, String name2)
at Autodesk.Intent.UI.DesignEditor.IntelliSense.MemberList.FindChildRule(IToken childRuleNameToken)
at Autodesk.Intent.UI.DesignEditor.IntelliSense.MemberList.m_syntaxEditor_DotTriggerActivated(Object sender, TriggerActivatedEventArgs e)
at Autodesk.Intent.Common.UI.SyntaxEditor.SyntaxEditorControl.RaiseTriggerActivated(Action`1 activated, IToken token)
at Autodesk.Intent.Common.UI.SyntaxEditor.SyntaxEditorControl.syntaxEditor1_DotTriggerActivated(Object sender, TriggerEventArgs e)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.OnTriggerActivated(TriggerEventArgs e)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.a(TriggerEventArgs A_0)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.a(EditorView A_0, Keys A_1, Char A_2, Boolean A_3)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.OnKeyPress(KeyPressEventArgs e)
at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
at System.Windows.Forms.Control.WmKeyChar(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Employee
JackGregory
Message 7 of 21 (340 Views)
01-30-2013 11:54 AM in reply to: omarutov
Can you tell us how you are getting this error?  I need some steps to replicate.
--Jack Gregory
omarutov
Message 8 of 21 (334 Views)
01-30-2013 12:40 PM in reply to: JackGregory
I have open sheet of drawing through Intent.
Child FrontView As ...
End Child
Child RightView As ...
End Child
Child PartsList As ...
End Child
Child Notes As ...
End Child
Every time when I try to type number (double type), after typing "." I have message shown above. It doesn't matter where I try to type number. In ETO R1 I didn't have with issue.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Employee
JackGregory
Message 9 of 21 (324 Views)
01-30-2013 01:08 PM in reply to: omarutov
Sorry, I am unable to replicate this with the information given.  Does anyone else have this problem?
I suppose I should say that ETO Studio is the preferred/recommended rule editing environment over Design Editor starting with Inventor ETO 2013 R2.
--Jack Gregory
omarutov
Message 10 of 21 (321 Views)
01-30-2013 01:18 PM in reply to: JackGregory
It doesn't matter what I use. Visual Studio or Design Editor. It must work. About previous information. For replicate this issue you need to create drawing through Intent. When you will have blank sheet on the screen. Go to into sheet design and try to type any double number. Done.
Win7 x64
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Post to the Community
New Post
Need installation help?
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
