I have an rule in Intent, when i am evaluating the specific rule in Intent returns the expected result.
But while trying with "GetRuleValue" function from WebUI, I am getting null value.
Do "GetRuleValue" evaluate the rule or whether, i need to follow any other steps to evaluate the rule.
Please help me in solving this issue.
Thanks in advance.
In my tests GetRuleValue() is getting the value. This is from a web application I used to test:
Object theLengthOfMyFrame = GetRuleValue("LengthOfMyFrame", "Root");
The Staircase ETO Web sample uses GetRuleValue(). (Other Web samples probably do also)
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292
I am not sure what is wrong in your project. If you attach a small example I can research it for a solution.
Wayne
