Hello there,
I just ran into an issue creating a new ETO project.
I created a new project, copied all templates I need in a sub-folder, changed the units to mm in all of them and set the project's template folder to that sub-folder.
I then started creating a part file, using mm length units. After I was done, I adopted it into Intent using the wizard. However, the resulting design insisted on using inch length units. After several failed attempts to fix this (setting the application defaults to mm and DIN, deleting all superfluous templates, going through quite a few option dialogs trying to find a setting that might cause this, etc) I gave up and copied an already existing project that successfully adopts part using mm as length units.
Basically, I didn't fix the issue and haven't found the reason for it, either. All I've found about ETO / Intent and length units so far was a post here saying that ETO handles units automatically. So, my question is this: Where does ETO get the information about what length units to use? It would be great if I could create new projects that use the length units I want.
Solved by wayne.brill. Go to Solution.
Solved by rikard.nilsson. Go to Solution.
Hi Rikard,
thanks for your reply.
I wanted to try your suggestion and created a new test project with the default settings. After that I opened the ipj file in a text editor and tried to find a mention of "inch". Sadly, I didn't find anything.
Perhaps I did misunderstand something. Is the project file you're talking about indeed the .ipj file or are you refering to something else?
Regards
Matthias
There is a way to set the units for a project in the UI. From the application drop down menu (Big I in the upper Left) Select Manage>Inventor ETO Project Manager. In the dialog there is Length Units drop down. If there are no open documents you can change the setting. There is some documentation about this:
http://help.autodesk.com/view/ETOCOMP/2015/ENU/?guid=GUID-6029AE8C-1A16-42D8-9F6C-EF351D0F0F30
Wayne
Hi Wayne,
In my Inventor that Options disapeared in 2015..
The last time a saw that was in 2014..
/Rikard
Hi Rikard,
In my install of ETO 2015 the setting is still there. I attached a screenshot.
I have English version:
Inventor - Build 2015 RTM Update 2
ETO - Version 8.1 Build 5 Date 6/5/2014
Wayne
Try one more time to add the screenshot.
Wayne
Hi Rikard,
I can get my "Manage" menu to look like yours if I uncheck "Intent Model" on the "User Interface" drop down on the View Tab and restart Inventor. Could you check this?
Wayne
