Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Using System...Dictionary from Intent
1 REPLY 1
Jon.Balgley
544 Views, 1 Reply
In this morning's "ETO Potlatch", Farren asked about using a System.Dictionary.  Here is a simple example.  Note that you cannot use "New", but you have to use CreateInstance.
Uncached Rule TestDictionary As List
   Dim map As Any = System.Activator.CreateInstance("mscorlib", "System.Collections.Generic.Dictionary`2[System.Int32,System.String]").UnWrap()
   map.Add(3, "Hello")
   map.Add(42, "Goodbye")
   Dim intentList As List
   Dim kv As Any
   For Each kv In map
     intentList = intentList + {kv.Key, kv.Value }
   Next
   Dim retList As List
   If (map.ContainsKey(3)) Then
     retList = retList + { map.get_Item(3) }
   Return retList
End Rule
 Thanks Mike!
Jon Balgley
1 REPLY 1
FarrenYoung
in reply to: Jon.Balgley
Awesome!  If only I had asked this question sooner. 😛
Thanks for this
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
