Inventor Engineer-to-Order
Board Manager
Jon.Balgley
Message 1 of 2 (175 Views)
Using System...Dictionary from Intent
175 Views, 1 Replies
10-11-2012 03:39 PM
In this morning's "ETO Potlatch", Farren asked about using a System.Dictionary.  Here is a simple example.  Note that you cannot use "New", but you have to use CreateInstance.
Uncached Rule TestDictionary As List
   Dim map As Any = System.Activator.CreateInstance("mscorlib", "System.Collections.Generic.Dictionary`2[System.Int32,System.String]").UnWrap()
   map.Add(3, "Hello")
   map.Add(42, "Goodbye")
   Dim intentList As List
   Dim kv As Any
   For Each kv In map
     intentList = intentList + {kv.Key, kv.Value }
   Next
   Dim retList As List
   If (map.ContainsKey(3)) Then
     retList = retList + { map.get_Item(3) }
   End If
   Return retList
End Rule
 Thanks Mike!
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Awesome!  If only I had asked this question sooner. :-p
Thanks for this
FarrenYoung
Message 2 of 2 (161 Views)
Re: Using System...Dictionary from Intent
10-11-2012 03:58 PM in reply to: Jon.Balgley
Thanks for this
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Manufacturing Community
