Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
UITools Tutorial in VS: Where are the user designs?
4 REPLIES 4
759 Views, 4 Replies
I loaded the UITools tutorial solution in VS 2010 (ETO2013R2) to work through the tutorial, but the user designs don't show up in the VS Design Navigator. They do appear in Design Editor if I load the Inventor project. What am I doing wrong?Capture.PNG
And a bonus question: What's the deal with the Type 'ErrorHandlerBehavior' is not defined. error. I get it after loading the project.
4 REPLIES 4
scott_anderson-adsk
It looks like you have only opened the UI Tools Tutorial.sln file. In order to view the UI Tools Tutorial designs in Visual Studio, you also need to use the "Import Inventor Project" command on the file menu, and open the "UI Tools Tutorial.ipj" file. This will create a "UI Tools Tutorial.etoproj" file which will list the designs in the Design Navigator.
The Type 'ErrorHandlerBehavior' is not defined error is due to the fact that the sample on the ADN site hasn't been updated to the 2013 R2 version yet. The update will be posted soon. In the meantime, you can open the RemoteUIIntentServices.vb file and replace
AspNetCompatibilityRequirements(RequirementsMode:=AspNetCompatibilityRequirementsMode.Required), _
ErrorHandlerBehavior()> _
with
AspNetCompatibilityRequirements(RequirementsMode:=AspNetCompatibilityRequirementsMode.Required)> _
However, you will also have an error in MainPage.xaml and will need to replace
<uiTools:UIProject x:Name="clientProject" ApplicationName="UIToolsTutorial" />
with
<uiTools:UIProject x:Name="clientProject" />
The application name now needs to be set in code. You can use the ETO Silverlight Web application template to see an example of how to do this.
Scott Anderson
Principal Software Engineer
in reply to: scott_anderson-adsk
Thanks Scott. Seems like the UI Tools tutorial is trying to be reference material AND tutorial at the same time. It could use some steps :).
stevetrudeau
The updated Server samples are now available:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292
in reply to: stevetrudeau
Thanks Steve.
