Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Tip: using relative paths for dependent ipj's
0 REPLIES 0
Message 1 of 1
ebachrach
468 Views, 0 Replies
Does your ETO project's Inventor project file contains dependent project references?  Are those dependent projects located nested under the primary project in your folder structure?
The ETO project editor, when creating these references, writes hard coded paths in the ipj, because the libraries may not be in nested folders, they could be in some other location altogether.  The result is that anyone else using the ipj must edit those paths to match their own file structure.
However, if the dependent ipj's are in nested locations under the windows directory of the primary project file, you can modify the text of the primary ipj to make those paths relative, so no one setting up your libraries has to edit those paths.
For example, suppose you a primary project file called Application.ipj, and you  have a directory structure relative to the primary ipj as follows:
Application <folder>
     application.ipj
     IntentUIframework <folder>
          IntentUIframework.ipj
     Customer_Generic <folder>
           Customer_Generic.ipj
The dependent libraries node can be written as follows:
            <Dependents>
                 <string>IntentUIFramework\IntentUIFramework.ipj</string>
                <string>Customer_Generic\Customer_Generic.ipj</string>
            </Dependents>
Elly
Elly Bachrach
ETO/CTO Solutions Designer
Intelligent Configuration Solutions
Mobile +1 (773) 401-6980
elly.bachrach@gmail.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Tags (2)
0 REPLIES 0
