Could be me, but I can't find the the system messages window of the newest ETO (2013 R2) release anymore ? Where can I find it in VS2010 ?
Cheers,
Mark
Solved by JackGregory. Go to Solution.
Looks like it's been combined with the Immediate window and called ETO Console.
View>Autodesk ETO Series Studio Windows>ETO Console
Hi Chris,
I've opened this window but I don't see any 'printvalues' ,that I placed for debugging purposes, appearing. Maybe they are visible somewhere else or could it be a setting ?
cheers, Mark
I haven't tried any printValue statements yet, I just saw the startup status messages sent to the console and assumed that was it. If I figure it out I'll let you know.
As part of the effort with getting error reporting improvements, along with server versions and such, we now have a real log. I didn't realize it when I first saw this thread, but that is where the PrintValue output is going. So if you navigate to your directory that looks something like this: C:\Users\<you>\AppData\Roaming\Autodesk\Inventor ETO Components 2013\Logs
you should find the log file, and can see all the stuff that you thought had disappeared into the ether.
Logging across processes (from Inventor to ETO Studio, for example) is kind of problematic. In addition, this is still a work in progress; not everything that should go to the log does. Hopefully this info will help with PrintValue usage at least.
If you are still using the old Intent Design Editor then you will be able to get System Messages back in the same way that you can re-activate the old IDE.
To Activate See: http://wikihelp.autodesk.com/Inventor_ETO/enu/2013/Help/0000-What_s_N0
After it is activated and Inventor is restarted, you will find the System Messages under Tools->ETO Panel.
