Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
System Function "removeIf?()" doesnt exist?
3 REPLIES 3
JamesNordgren
744 Views, 3 Replies
Hello, I am trying to set a the part1 reference for a Linear dimension to be only the odd-indexed children of another part.  I follow the examples given in help, and the code compiles but gives the error "No such method 'removeIf?'"
Child ToLeftGussets As :IvLinearDimension, Quantity = 3
			part1 =  nth(removeIf?(even?(Child.index, Model.FrameGusset)))
			entity1 = "Edge:5"
			part2 = Model.FrameChannel
			entity2 = "Vertex:1"
			textOrigin = funcpointLnrDimOffset((If bTop? Then :Up Else :Down), 1)
			formattedText = "<DimensionValue/>"
			dimType = :horizontal
			centerText? = True
			arrowheadsInside? = False
		End Child
 Can anyone help or see why this doent work?  I am running
3 REPLIES 3
Lesoux
in reply to: JamesNordgren
I would make something like that.
Child ToLeftGussets As (If odd?(Child.index) Then :IvLinearDimension Else :NullDesign), Quantity = 3
			part1 =  nth(Child.index, Model.FrameGusset)
			entity1 = "Edge:5"
			centerText? = True
		End Child
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
JackGregory
It is an odd error message, and I consider that a defect, but I think it doesn't recognize the call to removeIf? with one argument. And, actually, even? with two arguments should probably error as well.  I will investigate the error handling here.
JackGregory
in reply to: JackGregory
I looked into this, and we have a documentation bug that I think is causing the confusion.  The answer is, there is actually no function removeIf?, just like it says.  There is documentation for such a function, but you might notice in the examples shown in the documentation, the function actually being called is removeIf, without the question mark.  This makes sense, since we only use the ? on a function name if it returns a boolean, and this function returns a list.
Also, the first argument must be the Name of a function.  So you need :even?
So I will get the documentation corrected.  Thanks for finding this.
As a side comment, hard-coding the quantity, and then applying a function that returns a list is a bug waiting to happen.  The quantity should be based on the list length.  Pulling these out into a rule would make it a lot clearer.  Then quantity could be the length of the list produced from the removeIf function, and the nth(child.index, <list>) would be pulling from a list that is guaranteed to be of the same size as the quantity.
