Inventor Engineer-to-Order
Active Contributor
1 Kudo
Post 1 of 2
Sub-Assemblies change their Document Settings \ Units
197 Views, 1 Replies
01-28-2013 08:41 AM
Hello All,
The sub-assemblies called in as children change their document Units of Measurement from Inches to Centimeters:
Even though all the sub-assemblies were originally made from the Inches template (Automation(in).iam) (with all the parameters being passed in inches), and if I open them individually, they are in still in inches.
But when they are added as children, the document settings change to make them set to cm.
Example at hand:
(Main Assembly, with the documents settings being inches)
(if I drill into a sub-assembly, the document settings show that units have changed to cm)
All help is appreciated.
Thanking you,
Wajih
Hi Wajih,
It appears to be a known problem that the unit of the sub-assembly will changed after its called in as children in some cases, which we are looking into, you may need to manually change the unit for now.
Amanda
Employee
2 Kudos
Post 2 of 2
Re: Sub-Assemblies change their Document Settings \ Units
02-04-2013 07:18 PM in reply to: WHassan
Hi Wajih,
Amanda
Manufacturing Community
