Inventor Engineer-to-Order
Distinguished Contributor
ludesroc
Message 1 of 7 (175 Views)
Sort using 4th element?
175 Views, 6 Replies
11-08-2012 06:08 AM
Is there a way to sort a list using the 4th element?
sort(iList, :Ascending, key := :first)
sort(iList, :Ascending, key := :second)
sort(iList, :Ascending, key := :third)
sort(iList, :Ascending, key := :fourth)
Luc
Ludesroc
The key parameter takes any function.  So to sort the fourth you need to create a function that gets the fourth element.
For example:
Function fourth(inList As List) As Any
    Return nth(4, inList)
End Function
This will also work in other functions, such as Find
Find(myValue, iList, key:=:fourth)
You're welcome.
To make the function system wide, place it in "C:\Program Files\Autodesk\Inventor ETO Components 2012\Library\UserLib" (adjust for your version of eto)
Also, if you found my solution helpful I would appreciate any kudos you would like to give (Accept as Solution is great too).  The two of these are used as a part of the formula to determine a users' "Ranking" and I'd like to increase mine :-p
http://forums.autodesk.com/t5/FAQ-How-To-Using-Autodesk/Kudos-New-April-18/m-p/2993368/highlight/true
http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/How-Postings-Kudos-and-correct-answers-Equate-to-Rankings/m-p/3463612/highlight/true#M2287
FarrenYoung
Message 2 of 7 (173 Views)
Re: Sort using 4th element?
11-08-2012 07:19 AM in reply to: ludesroc
For example:
End Function
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
ludesroc
Message 3 of 7 (168 Views)
11-08-2012 07:58 AM in reply to: FarrenYoung
Thanks Farren! That's exactly was I was looking for!
Now, I can I get this new function to remain in the functions list permanently?
Luc
Ludesroc
FarrenYoung
Message 4 of 7 (165 Views)
11-08-2012 08:18 AM in reply to: ludesroc
You're welcome.
http://forums.autodesk.com/t5/FAQ-How-To-Using-Autodesk/Kudos-New-April-18/m-p/2993368/highlight/tru...
http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/How-Postings-Kudos-and-correct-answers-Equa...
--Farren
ludesroc
Message 5 of 7 (160 Views)
11-08-2012 08:23 AM in reply to: FarrenYoung
Great! Thanks again!
Maybe one day I'll be a mentor as well :smileywink:
Luc
Ludesroc
Employee
ebachrach
Message 6 of 7 (152 Views)
11-08-2012 02:52 PM in reply to: FarrenYoung
Farren's answer is correct.
Keep in mind though that the fourth function he wrote , using nth(4, mylist) does not work in the same way that first,second and third do, nth(4,{3,2,1}) returns 1 (i.e. the last element of the list), thirst({3,2}) returns novalue.  No difference if your lists have the correct number of entities of course.
Elly
Elly Bachrach
Solutions Architect
Autodesk Global Services
Direct +1 (847) 676-2880
elly.bachrach@autodesk.com
Active Contributor
Chris_Rogers
Message 7 of 7 (140 Views)
11-09-2012 10:44 AM in reply to: ebachrach
The function below will cause it to work the same as :first, :second, and :third.
    If length(inlist) < 4 then
         Return NoValue
    Else
    End If
End Function
-Chris Rogers
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
Manufacturing Community
