Inventor Engineer-to-Order
Active Contributor
alundr
Message 1 of 8 (319 Views)
set iProperties
319 Views, 7 Replies
08-16-2012 10:48 AM
I'm trying to set the iProperties value Mass.  I'm using a placeholder block to cut down on the graphics load, but I still want the part to reflect the correct weight load and weight distribution.  I'm starting with the flollowing code:
child block as :block, quantity = 4
    iProperties = {{"Mass", 8}}
end child
the value shows up here
but not here
how do I pass the value through?
Andrew
Employee
venkatt
Message 2 of 8 (299 Views)
Re: set iProperties
08-16-2012 04:23 PM in reply to: alundr
Not sure why this isn't working for mass properties. The same technique seems to for custom properties, e.g.
 iProperties = {{"test", 200.0}}
Then a custom property is added:
Employee
AlexKorzun
Message 3 of 8 (286 Views)
Re: set iProperties
08-17-2012 06:42 AM in reply to: alundr
iProperties are stored in the Inventor document/file (IPT, in your case). If you switch to the ClientGraphics implementation of the block, there will not be a document behind it.
You may consider adding the Parameter/Rule to keep the value of the mass.
Thank you,
Alex Korzun
Autodesk Configurator 360 / Inventor ETO team
Active Contributor
alundr
Message 4 of 8 (281 Views)
Re: set iProperties
08-17-2012 07:05 AM in reply to: alundr
I'm not sure what you mean by "adding the Parameter/Rule to keep the value of the mass".
What are ClientGraphics?
Do you have an example of how I would go about doing this?
What do you mean by "keep the value of the mass"?
Andrew
Employee
AlexKorzun
Message 5 of 8 (278 Views)
Re: set iProperties
08-17-2012 07:42 AM in reply to: alundr
Create new Design that extends block:
Design BlockWithMass : Block
	Rule Density As Number = 10.0
	Rule Mass As Number = Me.width*Me.height*Me.length*Density
Parameter Rule Mass1 As Number = 0.0 End Design
Create the child list in your assembly:
Child block As :BlockWithMass , Quantity = 5
    width = child.index
    height = child.index
    length = child.index
    origin = Point( child.index*2, 0, 0)
    Mass1 = 8.0
End Child
Please note that Mass is a Rule (which is calculated from the block size), and Mass1 is a Parameter, that can be specified during creation of the BlockWithMass
Mass of the block 3 will be determined as:
Intent >block_3.mass
--> 270.0
Intent >block_3.mass1
--> 8.0
Intent >
Thank you,
Alex Korzun
Active Contributor
alundr
Message 6 of 8 (266 Views)
Re: set iProperties
08-17-2012 11:29 AM in reply to: AlexKorzun
what does the iv_setProperty method do/how does it function?
Employee
AlexKorzun
Message 7 of 8 (259 Views)
Re: set iProperties
08-17-2012 12:14 PM in reply to: alundr
The first argument to the function iv_PropertyPut should be an Intent Part. The implementation tries to find the Inventor Document that owns the property.
In your case, Block will not have the Inventor Document behind it, so Intent will try to find the Document in Block's parent.
Thank you,
Alex Korzun
Employee
venkatt
Message 8 of 8 (242 Views)
Re: set iProperties
08-19-2012 12:52 PM in reply to: AlexKorzun
If you're not able to set the mass using the default iProperties rule, as a workaround you can implement your own that calls the Inventor API, for example:
Method UpdateMass(Mass As Number) As Boolean
 Try
  Dim invApp As Any=%%InventorApplication
  Dim activeDoc As Any=invApp.ActiveDocument
  If activeDoc<>NoValue Then
   If activeDoc.DocumentType=Inventor.DocumentTypeEnum.kPartDocumentObject Or _
         activeDoc.DocumentType=Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
    Dim massprops As Any=activeDoc.ComponentDefinition.MassProperties
    massprops.Mass=Mass
    Return True
   End If
  End If
  Return False
 Catch Error
  Return False
 End Try
End Method
Manufacturing Community
