Anyone there knows how to use get and set while making VB calls on Intent 4.0 Build: 129. I think in Intent 2012 you do it as follows:
ptPosition = %%InventorApplication.TransientGeometry.CreatePoint2d(x, y)
view.Label.set_Position(ptPosition)
I saw that peace of code work on Inventor 2012, but in intent 2011 I get an error (it doesn't recognize the method set_Position()) I dont know if that is a new feature of Intent 2012 or if there is a different way to do it in inventor 2011.
Thank you all
There were major changes to VB calls between 2011 (4.0) and 2011 Update 3 (4.3). The 4.3 calls are going to resemble the 2012 calls. Is there a reason you are using 4.0? Anyone with access to 4.0 should also have access to 4.3, which is still 2011.
I just got a new computer a few weeks back. Probably the update was not installed. I check and see what happens.
Tank you Chris
Ah, ok. Check Subscription Center for 4.3 (2011 Update 3)
