Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ludesroc
660 Views, 2 Replies
Select Case
Is there a way to use SELECT CASE with (e.g. <=) operators??? Or am I forced to use (If Then Else) clause?
Select springModel
   Case "Spring2"
      Select load
          Case <= 75
              Return "White"
          Case <= 160
              Return "Yellow"
      End Select
End Select
Ludesroc
2 REPLIES 2
justinrice
in reply to: ludesroc
Andrew,
The following should do it:
Select springModel
   Case "Spring2"
      Select True
          Case load <= 75
              Return "White"
          Case load <= 160
              Return "Yellow"
      End Select
End Select
 Let me know if you need any further assistance,
Justin
Engineering Intent
JustinRice@EngineeringIntent.com
ludesroc
in reply to: justinrice
Thanks Justin!
Ludesroc
