Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
SectionView sheet property
3 REPLIES 3
ulvika
572 Views, 3 Replies
Hi, I'm trying to place BaseView  and SectionView on a different sheets by setting SectionView.sheet property, but my SectionView allways follows  BaseView. Can you point me to the solution?
3 REPLIES 3
FarrenYoung
in reply to: ulvika
I don't believe this will work like you're thinking. As far as I know the sheet you place a section view on must also contain the base view. What you should likely do is place a base view somewhere off the sheet so that it isn't visible and then base the section view on it so that it appears only the section view is on this sheet.
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
AlexKorzun
in reply to: FarrenYoung
That issue was corrected in ETO 2014 SP1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22424851&linkID=11268853
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
ulvika
in reply to: AlexKorzun
Thanks a lot, it helped.
