I need to save a 2D Drawing throud a Method so that it can be sent back by intent server and be displayed on the web. the problem i am having is this is the only solution i have found it does not save the 2D Drawing i have tried changing the refchain to the correct one but it throughs and error. Please help i am desperate here.
that is the link i am trying if anyone knows something better may i will try to put the method in the drawing next.
Solved by scottdwagner. Go to Solution.
