Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Save a 2D Drawing With a Method
1 REPLY 1
scottdwagner
431 Views, 1 Reply
I need to save a 2D Drawing throud a Method so that it can be sent back by intent server and be displayed on the web. the problem i am having is this is the only solution i have found it does not save the 2D Drawing i have tried changing the refchain to the correct one but it throughs and error. Please help i am desperate here.
http://forums.autodesk.com/t5/inventor-engineer-to-order/create-multi-sheet-pdf-from-eto-server/td-p...
that is the link i am trying if anyone knows something better may i will try to put the method in the drawing next.
1 REPLY 1
scottdwagner
in reply to: scottdwagner
fixed by putting the method in the drawing desing.
