Please see the next order for generating 3D and drawings.
Run Inventor ->
Run Add-in (has been created for transfer data from database to Intent and works as interactive app for update some 3D model parameters) ->
Open Job # (transfer data from database to app) ->
Build 3D (build-in option into app).
All variables transfers to Intent through Dynamic Rules as lists. All children parameters in Intent have a references to particular variables in the Dynamic Rules.
Intent starts generate the 3D model.
Model was builded.
As user I can change some parameters through app and update their through the build-in option in app as "Update Parameters". In this case app override Dynamic Rules and update 3D.
If I need to change some Intent code I open Intent Design Editor and do it.
Now I try to do the same with VS, but then I have active Intent model VS is empty.
I can see full structure of my project in VS (Design Navigator). I can see all my Design files (Solution Explorer).
Hovewer, ETO Model Browser, ETO Model Properties shows me message "There is no Intent model loaded in Inventor". How it possible? In Inventor the Intent model is active.
Please try this test:
- Close Inventor and Visual Studio
- Restart Inventor and VS
- in VS, load your solution
- in Inventor, create a new model with the "Create a new design automatically" option
Does VS connect to Inventor in this case?
No. I don't use menu "Create new file" as Intent Assembly. I use our app for that.
I'm recommending trying to create a simple empty Intent assembly only as a test. It might help us to figure out what is causing the problem between Intent and Visual Studio.
Yes, I have a connection with VS if I use your proposal.
OK, thanks.
Try closing that empty model, and then create one of your own models. Do you get a connection?
If not, please use the About Inventor (or About Inventor OEM) command and post a screenshot of the About dialog.
Hovewer, I need to repeat this way every time when I restart my machine. What would you propose?
I have ETO R2. Sorry, I didn't update my signature.
The first time you try after a reboot, Visual Studio doesn't connect with Inventor?
After it makes a connection, are you able to close VS and Inventor, then restart them and reliably get a connection?
Run VS -> Open Project -> Run Inventor -> Create empty Intent assembly through "Create new file" -> There is a connection between Intent and VS -> Close assembly -> Open my app -> Generate 3D -> There is a connection -> Close Inventor -> Close VS -> Run VS -> Open Project -> Run Inventor -> Run my app -> Generate 3D -> No connection.
I need to repeat trick with empty Intent Assembly for creating connection between Intent and VS every time when I close VS.
After you get a connection and Generate 3D: can you close that model, Generate 3D again and get a connection? Or do you have to Create New File again?
Yes, I have a connection if I close 3D and generete again through my app. It works so long as VS is open.
I don't know what is causing the problem. We will try to reproduce it.
I am not able to get a connection to VS using the approach above. I am able to run the solution from VS to launch a new instance of Inventor, but the debugging cycle time of that approach is too long (waiting on Inventor to start).
Are there some settings in VS that I need?
I had trouble throughout the weekend trying to use ETO Studio R2. I have done the following already:
George
Dell M6400
i7-2820QM @ 2.3GHz Quad Core
16GB RAM, 256GB SSD, Quadro 2000M
Windows 7 x64, SP1
Inventor 2013 - Build 138
ETO 6.1 - Build 140
I want to make sure you know that you can't debug Intent code even if you do get a connection this way. The only way to debug Intent code is to start Inventor from Visual Studio.
Do you have any Visual Studio add-ins or extensions loaded? Can you post the About dialog from your install of Visual Studio?
Hi Mike,
I learned that from the team here this morning. That is a bummer. I will be logging ADN issues with our discoveries on projects that depend on reference project libraries relative to performance when we run Inventor from VS for debugging.
George
