I'm trying to run a simple .dll from ETO but can't acheive anything!!!!
Here's my approach:
Copied the .dll is in the Design Files folder of the current project.
Tested in ETO --> Rule myValuesAdded As Number = ClassLibrary1.Class1.AddMyValues(5, 2)
I get --> No such method 'AddMyValues' while calling (static) on ClassLibrary1.Class1
' Here is the dll...
Public Class Class1
Public Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double)
Dim Result As Double
Result = Value1 + Value2
Return Result
End Function
End Class
' Created a simple form to test the dll...it works just fine!!!
Imports ClassLibrary1
Public Class Form1
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
Dim Add As New ClassLibrary1.Class1
TextBox3.Text = Add.AddMyValues(CDbl(TextBox1.Text), CDbl(TextBox2.Text)).ToString
End Sub
End Class
Any help would be appreciated.
See if the attached helps (code from Jon Balgley's Potlatch presentation on this topic).
Intent rules:
Rule cus1 = New vbclasslib.customer("Jon", "Balgley", "503-555-1234") Rule cus2 = New vbclasslib.customer("Jon", "Yelglab", "503-555-4321") Rule allCus = { cus1, cus2 } Rule allPhones As List For Each C In allCus allPhones = allPhones + {c.phone} Next C End Rule
Sanjay-
Hi Sanjay,
When evaluating allPhones, I get this error...
Error - vbclasslib.customer
Error Message:
vbclasslib.customer
Rule Stack:
Part: Root
Rule: cus1
Design: ViewWindow
Source:
Part: Root
Rule: allCus
Design: ViewWindow
Source:
Part: Root
Rule: allPhones
Design: ViewWindow
Source:
Next C
End Rule
Part: Root
Rule: %%EVAL_TEMP_1
Design: ViewWindow
Source:
Uncached Rule %%EVAL_TEMP_1 As Any = allPhones
Are there any other steps to follow prior to run a dll from ETO?
1- I closed Inventor
2- Copy the dll in the design files folder (of current project)
3- Restarted Inventor
4- ...
Try this instead
Public Class Class1
Public Shared Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double) As Double
Return Result
End Function
End Class
If you don't want static methods in your .net code, you could get an instance in your intent code.
Dim instance As Any = New ClassLibrary1.Class1()
Return instance.AddMyValues(5, 2)
End Rule
