Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
368 Views, 4 Replies
Remove duplicate list
I have 171 list and each list has 2 numbers. Some of the list are duplicates. Is there a function or loop that can do this.
Thanks, John
4 REPLIES 4
JackGregory
RemoveDuplicates.  Note, however, Scott Heide (see message below) found a defect in it when using a comparison function.  As long as you are satisfied with "Equal" as the comparison, it should work fine.  If it doesn't work in your particular case, please post a sample of the data, and I will look into it.
--Jack Gregory
in reply to: JackGregory
  RemoveDuplicates() will remove duplicates within One list. I am trying to remove duplicate lists.
Example: {{4.5,6},{2.5,6},{1.5,8},{4.5,6}}
Collect all list except because it is a duplicate list.
John
JackGregory
Intent >RemoveDuplicates({1,2,2,3})
--> {1, 2, 3}
Intent >RemoveDuplicates({{1,2,2,3}, {1,2,2}, {1,2,2,3}})
--> {{1, 2, 2, 3}, {1, 2, 2}}
Intent >
Using your exact list:
Intent >RemoveDuplicates({{4.5,6},{2.5,6},{1.5,8},{4.5,6}})
--> {{4.5, 6}, {2.5, 6}, {1.5, 8}}
It is recursive.
--Jack Gregory
wow...it works.
Thanks, John
