I'm in the process of setting up a "test" application using ETO 2013. I have some items working, and I'm adding in rectangles and circles into my assembly/design for reference. My ground plane is the XZ plane, so to get the rectangles and circles to be on that plane, I've added the value of "vector(0,0,1)" to the 'ydirection' parameter in the Frame category. When I do this with Text, it doesn't change the orientation. The text stays in the XY plane (see attached for screenshot).
Am I changing the proper parameter or is there a different one I should be using? Even if I'm using the wrong parameter, it's still inconsistent behavior between the different designs (all of which are 2D). Thanks.
Can you take a look at this blog post and see if it helps?
Also there is a topic in the Wiki help:
http://wikihelp.autodesk.com/Inventor_ETO/enu/2013/Help/0148-Inventor148/0307-Inventor307/0324-Tools...
One idea in this excerpt from that topic in the help is important to understand:
As its name implies, xDirection is a Vector parameter and specifies the direction of the x-axis of the localFrame. Somewhat at odds with its name, yDirection doesn't actually specify the y-axis. Since the axes must be orthogonal, and there is no restriction on independent parameters, the system uses the yDirection value merely to determine the plane and general direction of the y-axis. Thus, xDirection has priority.
If this does not help upload a small dataset that I can use to recreate the problem.
Wayne
Wayne,
Thanks for the reply, but the topics described didn't help me out.
All I'm trying to do is add in the standard Intent Text design (see attached) as a child to the top assembly (Intent assembly using inches), and have the text lie on the XZ plane. I've added rectangles and arcs (both standard Intent designs) and gotten them to lie on the XZ plane using the "ydirection" parameter, but the text doesn't change orientations with that parameter. I've tried providing a value for the ReferenceFrame on the Text design as well, but that didn't work either.
Is the Text design only meant to be used on drawings?
The samples provided here all refer to a parent design of a Drawing Document: Text Design
If you would need a sample dataset, please let me know what I'd actually need to provide. I know my way around an older version of Intent, but I'm a novice when it comes to Inventor.
Thanks.
