Is it possible to export work points on derived parts using IvPartExtrudeFeature so that the work points are visible in the intent controlled part created using IvPartExtrudeFeature. I've tried marking the work points as export on the base part but they're not visible when the part is created. Is this possible or am I going about it the wrong way?
-Chris Rogers
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
