Someone know what is it mean? Next bug?
I have this error message when I try to adopt linear dimension from drawing to Intent.
The drawing was generated using Intent.
I'm using ETO version 5.1
It does mean there is a defect. If you could report this to the ADN support people, with some way to make it happen, we can fix it, or at least verify that it is fixed in the next release.
Thanks for replay. Could you help me? How I can to report this essue to the ADN? Sorry, but I don't know.
All Intent/ETO support for defect reporting is through ADN. If you are a member of ADN, you would login there and create a case (I think that is what they call it). If you are not a member of ADN, then you should contact whomever you get your ETO from and find out why, because you are supposed to be ADN if developing with ETO. At least that is my understanding.
Thanks!!!
