Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
MakeName() Failing
4 REPLIES 4
575 Views, 4 Replies
MakeName() Failing
Has anyone experienced this while using the MakeName Function.  When I run the following in the immediate window:
MakeName("Test" & char(160) & "String")
I get this error:
It appears MakeName as a problem with converting the ascii Character 160.
4 REPLIES 4
JackGregory
This is an interesting error message, but MakeName needs to have a legal Name in the string it is given, and char(160) is not a legal name character.  160 is Unicode 00A0, which is a non-breaking space, which is considered whitespace, and these are not legal in identifiers.  I agree the error message could be a lot more clear, but that is the bottom line.
The workaround is to use a legal name character.  The rules for names and identifiers are in the help.
ebachrach
Perhaps for your needs you could use char(32), which is supported?
Elly
Elly Bachrach
ETO/CTO Solutions Designer
Intelligent Configuration Solutions
Mobile +1 (773) 401-6980
elly.bachrach@gmail.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
in reply to: ebachrach
Thanks Elly that is exactly what I did:
<%%Category("CustomFunctions")> _
Function CustomMakeName( str As String) As Name
	Dim s_ModStr As String = NoValue
	If str.contains(Char(160)) Then
		 s_ModStr = StringReplace(str, Char(160), Char(32))
	Else
		s_ModStr = str
	End If
	Return MakeName(s_ModStr)
End Function
JackGregory
Since MakeName is documented to replace "illegal" characters with an underscore, I have entered a defect DE2116 to get it fixed.
In addition, based on this question, we discovered that the Name datatype had been left out of the documentation!  That too, is getting fixed.
