Someone tried to use an IvLeaderNote.
I don't understand how it works.
Why it doesn't works the same as diameter dimention?
Use 'part1' and 'entity1' as point to position of the market point.
Use 'textOrigin' parameter as point to position of the text.
It's easily.
IvLeaderNotes do not work the same as dimensions.
For a leader note, you will need the point where your text will be placed, the point that you want to point to, and the text that you want to use.
Example:
Child MyLeaderNote as :IvLeaderNote
sheet = Parent
leaderPoints = {TextLocationAsPoint , PointLocationAsPoint}
formattedText = "Anything"
End Child
Thanks for replay.
I know about that. It's not comfortably.
Ok. How are you will define particular position of the marker point in case changing scale or changing view location?
In this case you need to change the positions of market point and text every time.
I mean If you will have possibility to connect the leader note to some entity of part it would be better.
Your entity is probably based off of some logic on the part. You can use that logic to drive the point location. If you place the IvLeaderPoint in the IvBaseView then the point will move with the view and work with its viewscale.
Example
Rule PointLocationAsPoint as Point = Point(-(Me.Width/2) + (Model.HorizontalOffset * viewscale) , -(Me.Height/2) + (Model.VerticalOffset * viewscale) , 0)
Thanks, I'll try.
