Inventor Engineer-to-Order
Distinguished Contributor
ludesroc
Message 1 of 5 (278 Views)
IvPartExtrudeFeature
278 Views, 4 Replies
08-14-2012 06:02 AM
I'm looking for a good example on how to use this command (:IvPartExtrudeFeature). I would like to cut a rectangular hole (opening) on a sheet metal part. I created and adopted both the sheet metal and the opening part. I have a sketch (visible & exported). Sheet metal part is resides in an Assy.
Using ETO 2012 Version 5.1 Build: 322
Luc
Ludesroc
ludesroc
Message 2 of 5 (251 Views)
Re: IvPartExtrudeFeature
08-15-2012 11:51 AM in reply to: ludesroc
Never mind, I figure it out (thanks to Andrew :smileywink:)
1) Created a sketch Part (sketch visible and exported).
2) Named the sketch = sketch_Opening
3) Adopted the sketch part.
4) Added these child rules inside the part to cut.
'CODE
Design FloorLiner : M0122_TestZonesAdoptedComponents FloorLinerAdopt
'Sketch Part
Child FloorOpeningSketch As :FloorOpeningSketch, Quantity = length(openingSizes)
visible? = False
OpeningX = nth(1, nth(child.index, openingSizes))
OpeningY = nth(2, nth(child.index, openingSizes))
YOffsetFromOrigin = nth(2, nth(child.index, openingLocations)) - tubingWidth - gapAroundFloorLiner
XOffsetFromOrigin = nth(1, nth(child.index, openingLocations)) - tubingWidth - gapAroundFloorLiner
End Child
'Extrude Feature
Child LinerOpeningFeature As :IvPartExtrudeFeature, Quantity = length(FloorOpeningSketch)
distance = 10
operation = :Cut
extentDirection = :smileyfrustrated:ymmetric
sketchPart = nth(child.index, FloorOpeningSketch)
sketchName = "sketch_Opening"
face = "XY Plane"
origin = "Center Point"
xAxis = "X Axis"
reverseSketchNormal? = False
reverseXdirection? = False
End Child
End Design
'END OF CODE
Luc
Ludesroc
Employee
Chris.Palmatier
Message 3 of 5 (236 Views)
08-16-2012 01:24 PM in reply to: ludesroc
Hi Luc,
If you're working with sheet metal parts, look at IvSMPartPunchFeature instead of ivPartExtrudeFeature. It's simpler to use and is beffer for situations where you have multiple feautres, as you simply supply a list of points and faces. No need for sketches.
There is a sample in the ETO Samples project.
Chris Palmatier
Customer Success Engineer
ludesroc
Message 4 of 5 (224 Views)
08-17-2012 05:46 AM in reply to: ludesroc
Thanks Chris for the advise!
I had lots of trouble make it work. I found that iLogic rules and IvPartExtrudeFeature don't collaborate very well when mixed together. I logged a case (Case 07545190 - IvPartExtrudeFeature vs iLogic rules). If i remove all iLogic rules from the part then everything works fine! I wonder if IvSMPartPunchFeature has the same behavior?
Luc
Ludesroc
Valued Mentor
jcneal
Message 5 of 5 (115 Views)
11-08-2013 12:32 PM in reply to: ludesroc
hi,
is it still a problem happening on you? it may happen on me soon.
thanks
Autodesk Inventor Professional 2014
Autodesk Product Design Suite Standard 2014
Microsoft Office 2007 & 2013
Windows 7 64bit
Synergis Adept 2014
Visual Studio Express 2010
Manufacturing Community
