Autodesk is happy to announce the release of Inventor ETO 2015. This release is compatible with Inventor 2015, Inventor OEM 2015, and Vault 2015.
As always, you can communicate with us here on the newsgroup.
Sincerely,
The Inventor ETO team
on the sub center, I've just access to 2015 version with Autodesk Inventor Engineer-to-Order Series.
Do you know when Autodesk Inventor Engineer-to-Order Server will be available?
Cheers,
-Bertrand
Hi Jon,
I'm an ADN member. Could you tell me where I can download ETO 2015? We are currently working with Autodesk consulting on a project and I'm having a terrible time even finding Inventor ETO 2015.
Chad Boss
Herman Miller, Inc.
I don't think there is such a document. Inventor ETO 2015 was a maintenance release to support Inventor 2015 and related systems like Vault.
Hi --
No, there is only support in English. But we can use Google Translate!
No, no es sólo un apoyo en Inglés. Pero podemos usar Google Translate!
You should be able to access the software directly from the Autodesk Virtual Agent 🙂
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
dear I only have a student account, so i cant get access to eto series 2015, 066-66666666, 666-69696969 those serial no. would not work, would you please tell me what to do, thanks in advance, merci beaucoup
please see the attached photo, that is wht happened when i enter serial no., or if u had a correct serial no., would you send me the serial no., thanks so much for your help
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
