Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Inventor Crashes when evaluating unitize(-Point(0,0,0))
1 REPLY 1
FarrenYoung
312 Views, 1 Reply
As the subject states, Inventor crashes if an attempt is made to evaluate unitize(-Point(0,0,0))
This can easily happen if one is subtracting points to get a vector to unitize and forgets the first point, or accidentally forgets to paste a value back in etc.
Can others please test this on your machine and let me know if you run into the same issue or if this is only happening on the version I'm running?
my installed version: 4.3.523
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
1 REPLY 1
In ETO 2012 SP1 O get the following:
> Intent unitize(-point(0,0,0))
Error - Uniary operation
An error was encountered while evaluating rule %%EVAL_TEMP in part Root
     An attempt was made to use the '-' operator on a Point
Chris Palmatier
Customer Success Engineer
Inventor Engineer-to-Order
