Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Intent doesn't generate the drawing!!!
6 REPLIES 6
Lesoux
537 Views, 6 Replies
When I try to generate the drawing from assembly through boolean rule, sometimes Intent doesn't responding and I see just empty sheet.
Does anyone have the same problem?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
6 REPLIES 6
Chris.Palmatier
in reply to: Lesoux
Too many vaiables to know what is wrong here. What version of Intent? What does your code look like?
Chris Palmatier
Customer Success Engineer
Inventor Engineer-to-Order
Lesoux
in reply to: Chris.Palmatier
I'm using v5.1. Sometimes Intent generates the drawings without any problems. I think it doesn't depend on code.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Chris.Palmatier
in reply to: Lesoux
There was an issue with regenerating a drawing after it already exists on disk. It's fixed in the latest, but I don't remember when it was fixed. The workaround for the older issue is to delete the drawing file on disk before regenerating it. Can you try that and see if it works, next time your drawing fails?
If that doesn't work, then I'll need an example case with steps to reproduce it here.
Chris Palmatier
Lesoux
Step by step:
1. Open Inventor.
2. Open the assembly.
3. Generate the drawings.
OK.
4. Close the drawings.
5. Close the assembly (Inventor stay opened).
6. Delete the drawings from local drive.
7. Open the assembly.
8. Generate the drawings.
INVENTOR IS NOT RESPONDING.
9. Close Inventor through Task Manager.
10. Delete the drawings from local drive.
11. Open the assembly.
12. Generate the drawings.
OK.
For correct generating the drawings I need to close Inventor, delete all drawings from local drive and repeat steps 1 - 3 as stated above. After that I can generate the drawing without any issues.
It's not too comfortable.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
TIMOHART
in reply to: Lesoux
Dear Chris ,
Will it be possible to post step 3 and 4 ?
Thank you / Regards
Timo
ETO 2014 R2
HP Z420 / Win7 X64
16GB RAM
Nvidia Quadro K4000
amandamao
in reply to: Lesoux
It won't occur in my side, is it possible to provide the data you use for our deep investigation?
Amanda
