Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Intent 3.3 Immediate Window Double Quote Bug
2 REPLIES 2
338 Views, 2 Replies
I've noticed the following inconsistency with the Immediate Window with Intent 3.3.
Consider the following code:
{code}
Rule FrameProp As String
com_msgbox("""")
Return """"
End Rule
{code}
The msgbox output is attached as an image. The immediate window produces the following output:
{code}
Intent >FrameProp
{code}
Why does the immediate window produce a double-double quote here? The first double quote and last double quote signify that a String was returned. But there's no need for it to signify the one double quote that is returned by the Rule as two double quotes.
TLDR: The Msgbox is correct. The immediate window is not.
Is this a bug?
2 REPLIES 2
major_xu
Intent syntax requires four quotes to represent a single-quote string. The message box displays the actual string ("), while immediate window shows the formula for a string ("""").
The behavior is as designed.
Alright, thanks.
