Show only
Search instead for
I've noticed the following inconsistency with the Immediate Window with Intent 3.3.
Consider the following code:
{code}
Rule FrameProp As String
com_msgbox("""")
Return """"
End Rule
{code}
The msgbox output is attached as an image. The immediate window produces the following output:
{code}
Intent >FrameProp
{code}
Why does the immediate window produce a double-double quote here? The first double quote and last double quote signify that a String was returned. But there's no need for it to signify the one double quote that is returned by the Rule as two double quotes.
TLDR: The Msgbox is correct. The immediate window is not.
Intent syntax requires four quotes to represent a single-quote string. The message box displays the actual string ("), while immediate window shows the formula for a string ("""").
