I found this comment in the %%IvCommonDimensionMixin and found it to be quite humorus.
note to self ... "Self, you should probibly do this. Sometime. Whenever you get some spare time."
'# This is specified as a sheet-relative point, but it will "stick"
'# with the view. [At least, that's what Inventor does. Probably(?) we
'# should change the interpretation so that it is view-relative.]
< %%Category("Inventor"), %%Prompt("Placement position for dimension text, in sheet coordinates") > _
Parameter Rule textOrigin As Point = Required
Also, what's the difference between the colors "grey" and "gray"?
~Andrew
ETO 2013 R2
