Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
385 Views, 1 Reply
How to delete a file
I want to delete the already created log file.
Below is the code I am using for writing the log file.
Dim
LogFile AsUser = openFile(ProjectLocation() + "\Output\" + "log.txt",:WriteAppend)
Dim a AsAny = write (ErrTxt,LogFile)
Return closeFile (LogFile)
Santosh
1 REPLY 1
FarrenYoung
After the file is closed, the following will delete it.
system.io.file.delete(ProjectLocation() + "\Output\" + "log.txt")
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
