Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Getting "Inventor.Application" is not defined or not registered correctly.
10 REPLIES 10
Message 1 of 11
santosh-kul
772 Views, 10 Replies
I am trying to access "Inventor.Application" through "COM_connectRunningServer". Below is the sample code for the same.
Dim
inventor AsUser = COM_connectRunningServer_("Inventor.Application")
When I run this through ETO server, I am getting the below error message.
Server "Inventor.Application" is not defined or not registered correctly.
I can run this properly on Inventor + Intent system.
Santosh K.
10 REPLIES 10
Message 2 of 11
Hi Santosh,
I think you should use %%InventorApplication instead. That returns a .Net object that you can use to access Inventor. It  will work with both ETO Series and ETO Server.
As to why your call isn't working, I don't know for sure, but I wouldn't be suprised if "Inventor.Application" COM access was not supported for Inventor Server. ETO Server makes use of Inventor Server under the covers, it is not full Inventor.
Ray
Message 3 of 11
Hi Ray,
Please find below the rule I am using. I have modified it as per your instructions. However now it shows that "%%InventorApplication" is not defined....
Uncached
Rule CreateSAT AsString
Dim inventor AsUser = COM_connectRunningServer_("%%InventorApplication")
Dim OpenDocument AsUser = COM_getProperty_(inventor, "Documents")
Dim i AsInteger
Dim ActiveDocObject1 AsUser
Dim FileName AsString
For i = 1 To length(PartsForOutput)
FileName = outputLocation +
"\SATOutput\" + nth(i,PartsForOutput).DisplayName + ".SAT"
COM_methodcall_( OpenDocument,
"Open",nth(i,PartsForOutput).CacheFileName ,True)
ActiveDocObject1 = COM_getProperty_(inventor,
"ActiveDocument")
COM_methodcall_( ActiveDocObject1,
"SaveAs", FileName ,True)
"Close", True)
Next
COM_releaseDispatch_( ActiveDocObject1 )
COM_releaseDispatch_( OpenDocument )
COM_releaseDispatch_( inventor)
Return displayName'
End Rule
Santosh
Message 4 of 11
Jon.Balgley
in reply to: santosh-kul
Try something like this:
Design MyInventorUtilities : walkwaysRoot
Method createReportImage() As String
Dim outputFile = "c:\temp\ReportImage.jpg"
Dim view = %%inventorApplication.ActiveView
Dim hasGnomon As Boolean = %%inventorApplication.DisplayOptions.Show3DIndicator
Dim displayMode = view.DisplayMode
Dim hasGroundShadow As Boolean = view.ShowGroundShadows
Dim hasAmbientShadow As Boolean = view.ShowAmbientShadows
Dim hasObjectShadows As Boolean = view.ShowObjectShadows
%%inventorApplication.DisplayOptions.Show3DIndicator = False
'view.ShowGroundShadows = True
view.ShowAmbientShadows = True
view.ShowObjectShadows = True
view.DisplayMode = Inventor.DisplayModeEnum.kRealisticRendering
view.RayTracingQuality=Inventor.RayTracingQualityEnum.kInteractiveRayTracingQuality
'view.GoHome()
Try
view.SaveAsBitmap(outputFile, 1200, 800)
Finally
%%inventorApplication.DisplayOptions.Show3DIndicator = hasGnomon
view.DisplayMode = displayMode
view.ShowGroundShadows = hasGroundShadow
view.ShowAmbientShadows = hasAmbientShadow
view.ShowObjectShadows = hasObjectShadows
End Try
Return outputFile
End Method
End Design
Jon Balgley
Message 5 of 11
Hi Sanathos
Sorry for the confusion, %%InventorApplication is an Intent Rule of type Inventor.Application, you don't need the COM_Connect or COM_getProperty, or any other COM stuff. Just use it like this:
%%InventorApplication.GeneralOptions.TextSize, %%InventorApplication.Documents, etc. Refer to the Inventor API docs for all the methods available.
Ray
Message 6 of 11
%%InventorApplication works on Inventor + Inventor ETO Component machine. However when I tried to use it on ETO Server it gives same error message.
%%InventorApplication is not defined or not registered
Santosh K.
Message 7 of 11
Hi Santosh,
What exactly are you running? Are you running this from the Intent Session Manager service, using the Server Configurator to setup your application? Is this a batch mode application run with InventorETOServer.exe? I'm not sure how either of those contexts could not find Inventor Server but it is a start to begin troubleshooting.
Can you also try to run InventorETOServer -i from the command and report back the results. It is located in the server install "bin" directory.
Ray
Message 8 of 11
Hi Ray,
I am running it on Inventor ETO Server machine with a web UI using the WCF service to start Intent Application.
Santosh
Message 9 of 11
ok, on the server machine please try to run:
from the command line and report back the results. It is located in the server install "bin" directory. This will tell us if your issue is a general problem with Inventor Server or a problem with the WCF Service.
Ray
Message 10 of 11
Hi Ray,
Please find below the output of "InventorETOServer.exe -i" command.
Santosh K.
Message 11 of 11
Hi Santosh,
ok, that all looks ok. I just tried a very simple test with something like this:
Parameter Rule MyRule as Any = %%InventorApplication.Documents.Count
can you add that rule, evaluate and see what happens? It worked fine for me.
Ray
