Is it possible to perform a :IvPartExtrudeFeature on a multibody part ?
It seems that the featue is only performed on the first body and I don't see any parameters where I can specify to which bodies the feature should apply.
Cheers,
Mark
Solved by Chris.Palmatier. Go to Solution.
Mark, we don't currently support multibody parts for ivPartExtrudeFeature. Can you create the required feature(s) in the part and use feature suppression?
Hi Chris,
Thanks for the swift reply.
I thougth that this was the case,so I started to change my partstructure and use only one body. I lack some structure now, but at least it works.
Mark
