Inventor Engineer-to-Order
Active Contributor
WHassan
Message 1 of 3 (177 Views)
Extracting co-ordinates of a Point
177 Views, 2 Replies
11-19-2012 02:59 PM
Hello all,
I am trying to get the X-coordinate of a point.
The code goes something like this;
Rule lstStdPanelParameters As List
    Dim counter1 AsInteger
    For counter1 = 1 To intNoStdPanels
     lstStdPanelParameters = lstStdPanelParameters + {{ _
              ":smileysurprised:rigin", Point(counter1 * numStdPanelLength,0,0), _
              ":xDirection", Vector(0, 0, 1)), _
              ":yDirection", Vector(-1,0,0)}}
    Next
End Rule
The value I need in a spearate rule would be something like;
Rule pntFirstPanelOrigin As Point = Second( First _
( lstStdPanelParameters))
Rule intOriginX As Number  = pntFirstPanelOrigin.x
I get an error when I evaluate this (last) rule, saying "Found a Point, where a Part was expected"
I also get the same error if I use a child (for example)
Rule intOrigin2X As Number = myChildName.origin.x
Support for all the helpers is approaciated.
Thanking you,
Wajih
the function localx(origin) should give you the value you are looking for.
Elly
There are also hidden functions GetX(), GetY(), and GetZ() which you might find useful.  I believe localX() will convert the point relative to a coordinate system and GetX() will get the x value and not do any conversion.  Someone can correct me if i'm wrong.
Employee
ebachrach
Message 2 of 3 (166 Views)
Re: Extracting co-ordinates of a Point
11-19-2012 08:45 PM in reply to: WHassan
Elly
Elly Bachrach
Solutions Architect
Autodesk Global Services
Direct +1 (847) 676-2880
elly.bachrach@autodesk.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
Message 3 of 3 (141 Views)
11-26-2012 07:23 AM in reply to: WHassan
--Farren
Manufacturing Community
