How can I delete a design from the Design Navigator window? There is no Delete command when (right mouse click) on a design.
You can delete designs (IKS files) using the Solution Explorer window ... but only when Inventor is not running. That behavior is in sync with how other languages work in Visual Studio, i.e., you can't remove files from the solution while it is running.
It is possible to add new designs/files while Inventor is running (unlike other languages), using the Design Navigator.
