Ok i have the IntentClient.InvokeMethod("Root","ExportImage") working i also have the ability to create a dwf with a custom method.
I can even export as Catia and Step. file. this is done through a custom application extension. what i need to do is either have a way to invoke a custom method using an application extension. or using the InvokeMethod technique. I just cannot find any information on these methods. If i knew what autodesk application extension to import into my custom extension to get to the export SLT.
Solved by JackGregory. Go to Solution.
Do you mean "STL"? If you can output Catia or Step, you should just be able to do the same thing with STL, but it is possible it is not available in your version or something. If you are spelling it "SLT", that might explain it.
On the general subject of server custom actions, there is a Potlatch next week on this very subject.
Yes i meant stl not slt. I was able to get this to work finally. had to write an Add-in to allow for the save copy as. thank you for your help.
