Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ETO independent Projekts linked with ETO Project Editor --> Now Vault ?
2 REPLIES 2
373 Views, 2 Replies
We face a major issue on how to get the ETO projects in Vault . My projects are independently developed so each assembly has its own root design. Finally I link all the roots together using the ETO Project Editor.
Now we need to get them into Vault and this fails cause the linked projects are not seen by Vault . Is there any advice how to solve this issue or do we completely need to rethink our phylosophy ?
Thank you / Regards
Timo
2 REPLIES 2
ebachrach
I assume that when using vault, you must use the vault project file which doesn't have your libraries identified.
Is that correct?
If so, that perhaps you can add your dependent libraries to the Vault ipj?  you can see what that is supposed to look like in the ipj file by opening yours.  there is a list of dependent libraries.  You can add just your root one to the Vault ipj, and your root library's ipj file has the rest of those libraries lsited in it's dependent libraries value.
Elly
Elly Bachrach
ETO/CTO Solutions Designer
Intelligent Configuration Solutions
Mobile +1 (773) 401-6980
elly.bachrach@gmail.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
in reply to: ebachrach
Thank you for this approach Elly ,
It seems I am not allowed to do this with a vault project .
Any other Idea or am I doing something wrong ?
Thank you / Regards
Timo
